255/75/17 what other tires sizes will fit to replace this size.
I am getting ready to buy new tires...Want to know what other sizes will fit my rims...2008 wrangler X
with Factory Alloy rims with 7.5....Ruger48...Thank You
Not really sure what your question is. Any tire size with r17 will fit your rims. If you are looking for the exact same size go stay with the 255/75/17. If you are looking to upgrade look into 33's or 285/70/17 or 285/75/17. Just make sure the last numbers are 17. Hope that helps.
I'm going to go out on a limb and assume that the OP was wanting to know what other sizes fit but still remain the same height as the stock 255/75/17s. If you want to go wider 275/70/17 is virtually identical in height.
