285/70r17 Duratac user help please
Old Jul 21, 2010 | 05:21 PM
White Fang's Avatar
Default 285/70r17 Duratac user help please
I've had my wrangler a little over a year and a half and Im starting to get the itch to move up to a 33" tire and get the teraflex leveling kit (something thats easy to take off when I take it into the dealership so it won't void my lifetime warranty ) . Mine came with the 255s and rubi wheels. Now where I get confused is that everyone says that the 255/75 is a 32" tire when it only measures about 30.5 . Is the 33 measurement before the tire is mounted and inflated?
Also could I get someone thats running the 285/70r17 duratrac (with stock 17 wheels if possible) take a photo with a tape measure from the ground to the top of the tire like I've taken.....Pretty please.....maybe with a little sugar on top
Old Jul 21, 2010 | 05:31 PM
treadmark's Avatar
Default tire measurement
The diameter is measured based on the mounted and inflated diameter on a specified width rim according to the manufacturer's respective site. Measuring while under the weight of the vehicle will result in a smaller diameter.
Old Jul 22, 2010 | 04:30 AM
White Fang's Avatar
My spare has never been used and almost the same measurement (30.5") as the tires underneath the jeep.
Old Jul 22, 2010 | 07:53 PM
Weeds's Avatar
Goodyear has dimensions on their website. They may not be perfect but close.
Old Jul 23, 2010 | 09:05 AM
White Fang's Avatar
They say mine (255/75) is 32.1" but it actually measures around 1.5 to 2" smaller....Mabe its the same with the 285/70 and it actually measures 31-32"? You'd think that a 32" tire would be 32 and the same for a 33". this is getting confusing.
Old Jul 23, 2010 | 09:23 AM
Widewing's Avatar
Tire diameter is defined as measured uninstalled....
I have a set of 285/70-17 Maxx Traction Dunlops sitting in my garage, not yet mounted on wheels. If I roll one out and stand it up next to the 285/70-17s currently on my JK, they stand more than an inch taller.
In other words, it's normal. Don't worry about it.
Old Jul 23, 2010 | 10:16 AM
dstock's Avatar
I have the same Duratrac tire set up you are considering on stock rims and the Tereflex leveling kit. I'll try to post some pics, but when I measured the tire it was between 32 and 32 1/4. I'm not sure what your concern is exactly with the tire measurement. There is a slight rub on the swaybar at full lock. I just popped a washer (or two) under each steering stop and cured that issue.
Old Jul 23, 2010 | 01:32 PM
White Fang's Avatar
Its not really a consern. I just took out a tape measure to see how a 33 would look. I was suprised when my 32s were actually 30s
So its about a 2inch difference. Another question if you dont mind, how far out does your tires stick out past the fender?
I would really appreciate the pic, thanks
Old Jul 23, 2010 | 02:17 PM
dstock's Avatar
They don't stick out at all, I'd say they are just under to about a 1/4 inch under. Duratracs really change the look of the jeep, to actually look like a Jeep!
Old Jul 26, 2010 | 09:46 AM
dstock's Avatar
Default Some pics
Here's before:
And a few after:
