285 rubbing?
Old Jun 13, 2011 | 07:31 AM
JeepJk1's Avatar
Default 285 rubbing?
I'm thinking about getting some new 285's and I was wondering if they rub? If so how bad?
Old Jun 13, 2011 | 08:07 AM
Bernigoober's Avatar
I just got a set of 285/75/16 Duratracs. I also got new wheels with 4.25" back spacing. I have not had any rubbing. I don't have a lot of clearance between the front tires and the fender flares, but I think that's a result of the springs sagging from the bumper and winch.
If you aren't going to get new wheels too, would probably be a good idea to get some wheel spacers to use with your stock wheels.
Old Jun 13, 2011 | 09:33 AM
tljk2007's Avatar
Default I have 285 70 17's
I have 285 70 17's on factory wheeel and they rubbed the sway bar until I got wheel spacers. They have not rubbed anything since.
Old Jun 13, 2011 | 11:07 AM
Davep22's Avatar
I have 285/70/17s on ATX wheels with 4.5" backspacing. I have no rubbing whatsoever.
Ultimately, these tires will rub UNLESS you have wheels with 4.5" backspacing (or less) OR you use wheel spacers.
Old Jun 13, 2011 | 11:26 AM
speed2005's Avatar
Get some wheels with proper backspacing (ie Rugged Ridge or AEV) and you are set.
Old Jun 13, 2011 | 06:43 PM
KY HILTOPR's Avatar
Speed2005 is right - Proper B/S & you should be fine. {Get new wheels-you'll be glad you did} .
No rubbing at all from my Duratracs: 285/70/17 on ProComps
