295/70/17 regear?
Curious how tires have worked out? Currently JKU Willys Wheeler 2017 stock wheels, 3.73 ratio, no lift/no spacer. Looking to move from 255/75R17. Will be adding Spidertrex 1.5" adapters but not lifting yet. Looks like 285/70R17 would be fine but now thinking 295/70R17. Thought?
Hey Rob, policies vary greatly across the regions. Since you mention spacers, you might inquire with your local tire stores if they have any specific policies regarding those. Some areas, like here in DFW, shops won't tough a vehicle with spacers due to liability issues, which makes getting tires mounted, and keeping tires balanced, a real hassle. Just test the waters before rather than after you add them.
I'm a little confused as both are essentially the same thing, cept that "adapters" would be used to change the lug nut pattern (say from 5x5.5 to 5x5) and "spacers" are keeping the same pattern. Both will go between the brake rotor and the wheel and require an additional set of lug nuts.....which is the cause for liability concerns. Seems like they'd either be ok with both, or neither. I wonder if by "adapter" they are thinking an adapter ring for a hub.....as in you have aftermarket wheels but the hub bore in the new wheel is larger, so you use an adapter ring to match the hub up to the bore in the new wheel? It's really up to you to confirm. I just know it's a rude awakening to have spacers and not have anyone willing to work on your vehicle.
I'm wondering if, from the tire shop's standpoint, the terminology is a legal issue for them based on the idea that a "spacer" can include the cheap do-not-ever-use versions that just reduce the amount of available stud thread, while an "adapter", by definition, has to include a separate set of studs?
