2wd high stock e-locker
Old Aug 24, 2008 | 01:54 PM
MUDNINJA's Avatar
Default 2wd high stock e-locker
i was wondering if anyone knows how to get the lockers to work in 2wd high instead of just in 4low
Old Aug 24, 2008 | 03:20 PM
wayoflife's Avatar
JK-Forum Founder
hmmm, while there might be a way to rewire things so that you can do this, you need to be very careful when doing this as if you mess up even a little, you can fry your whole computer.
Old Aug 24, 2008 | 03:32 PM
MUDNINJA's Avatar
has anyone out figured it out? i really need to do some 2 wheel burn outs, one wheel is just wussy
Old Aug 24, 2008 | 03:37 PM
jeeperjkj's Avatar
Yeah, I, too, am tryin' to figure out why you'd want to lock the rear in 2HI...
Old Aug 24, 2008 | 04:00 PM
MUDNINJA's Avatar
2 reasons , 2 wheel brake stands and drifting, if the diff is open when your drifting then you might flip the bitch cause the inside tire will not spin or slide so you'll end up tipping, i found that out in my old tj, it didnt flip but i was on 2 wheels at the balence point so i turned into it like the monster trucks do and down it came back on the tires. so if its locked the back end will slide out when you stay on the gas, cause the tires r spining witch means alot less fraction and traction
Old Aug 24, 2008 | 04:01 PM
jeeperjkj's Avatar
Hmmm.... drifting a JK. Seems I remember a pic of that around here somewhere...
Old Aug 24, 2008 | 05:50 PM
Dewkin's Avatar
There is a post regarding a write up to lock both the front and rear lockers in High if you want. Below is the link to the write-up.
https://www.jk-forum.com/forums/show...4%27s+Write-up
Old Aug 24, 2008 | 06:04 PM
RedneckJeep's Avatar
I cannot see how the JK would realistically have enough power to drift or burnout.
Old Aug 24, 2008 | 06:37 PM
w.wood jeepster's Avatar
You could totally bypass the computer and wire it to a switch. I have a sahara and added a dana 44 with elocker to the front. Its a simple 12 connection and you can wire an LED to tell you when it is locked.
NOt quite sure why you would want to do it anyway but it can be done.
Old Aug 24, 2008 | 06:43 PM
MUDNINJA's Avatar
sweet thanks dewkin much appresiated, and driftin the jk is a good time to me and it does some big drifts in 2nd and 3rd in the rain and on the dry im limited to 1st or 2nd if the road is a bit dirty(only in parkin lots and back roads were im alone so its safe) and for the burnout hold the brake , rev the engine to 5 grand or so and let er rip and put on ur gas mask
