3.21's, 6spd, and 35's
Old Jan 25, 2010 | 01:08 PM
REDJK21's Avatar
Originally Posted by klutz1001
So my new wheels should be here this week and i figured since im remounting maybe i should think about stepping the tires up a size... just wondering from people who have a 6spd and 3.21's how bad 35's are... as much info as possible would be great like your tire, and how highway and city are ect.. thanks so much
I have this setup and the people who running it like me are right. Its not that bad as you would think. Its fine driving around the city and stuff but the highway kinda sucks. 6th gear is useless. Just do the 35's you wont regret it! the look is a huge difference, it'll motivate you to just do more to your jeep! Also look at at this way the 3.21's are bigger therefore much stronger to tug your jeep around. JK's are dogs to begin with so...
Old Jan 25, 2010 | 02:40 PM
JUSTIN01's Avatar
So what would the difference in price be for getting a new carrier vs. just getting new gears?
Let's say.....
price for someone to regear to 5.13 from 3.21
Price for someone to regear to 5.13 from 3.73 or 4.10
I've got the 3.21's and am interested about how much more regearing is going to cost. I want to do it all in one foul swoop.
Old Jan 25, 2010 | 03:32 PM
phljeeper's Avatar
Let's say.....
My understanding is that you can either replace the carriers or use thick gears. Either way it will cost you about 125-150 more for the regear over a Jeep with 3.73 or higher. Best option though is to add lockers when regearing and you would not need new carriers.
Old Jan 25, 2010 | 03:37 PM
Piginajeep's Avatar
true, but Lockers are not cheap!
atleast a good ARB is not
Old Jan 25, 2010 | 04:17 PM
Piginajeep's Avatar
Originally Posted by ECHO
So what are you looking at just re-gearing from 3:21's to 4:88 or 5:13 & do you need to do the front & the back axles at the same time? Probably a Duh Question, but I am going to ask it..
yes, its a must. Unless you want to run without a front driveshaft until you get the front done.
Old Jan 25, 2010 | 04:39 PM
officer_vince's Avatar
I run 35's and 3.21's. I ordered my Jeep with 3.73's but the dealership fucked that up so...yeah...they are assholes.
I have had the 35's on for about 1.5 years now and it's liveable but not ideal. I am saving for the almighty 5.13's.
Old Jan 25, 2010 | 06:11 PM
mjturner1105's Avatar
Default carrier
im going to go from 3.21s to 4.88s and will get them from northridge will the rear be a thick ring gear so the stock carrier will work. where can i buy a new open front diff also
Old Jan 26, 2010 | 05:15 AM
hammerhead's Avatar
I believe David at Northridge can get them for you and send them with you're gears. You can also pick one up at the dealer, it should only be about $60.00. Or while you're in there you might as well put in a Detroit Truetrac.
Old Jan 27, 2010 | 07:58 AM
Yellow93's Avatar
It will be the most miserable driving experience you have ever had! When I had that setup I couldn't use 6th at ALL and only use 5th on the highway straights... a hill meant I was going back to 4th or getting run over! I went with 4.88's and have been very happy!
Old Jan 28, 2010 | 01:12 PM
JUSTIN01's Avatar
My only beef is, I don't want a locker for the dana 30. I need to at least have a dana 44 before I would think about dropping cash into a locker for the front. It seems like a waste for the D30. A D60 and locker is in order for the rear, just wanted a crutch for the front until I save up for a front D44 or D60. Under a $200 difference is do-able I think.
