3.25 rough country problem
Old Jan 15, 2013 | 09:54 AM
eossncsb's Avatar
Default 3.25 rough country problem
just installed a 3.25 rc lift on my jk and it seems to be leaning lower on the back passenger wondering if someone may know whats going on
Old Jan 15, 2013 | 10:06 AM
bob-o's Avatar
Does Ur jk have a full tank of gas( if it does, maybe the coil is just sagging a little. Or maybe the right rear coil isn't seated properly. Check the left and right rear coils to see if they are in the correct position
Old Jan 15, 2013 | 06:39 PM
BADDANDY's Avatar
My RC 3.25 on my TJ did the same thing, even swapping the springs left to right. I wound up taking the driver side spacer out.
Old Jan 16, 2013 | 05:31 AM
Ryan0260's Avatar
X2 make sure springs are seated. Also, the gas tank when full tends to do this due to the location of it
Old Jan 17, 2013 | 05:56 AM
Rough_Country's Avatar
Sponsoring Manufacturer
What is the varriance between the corners? HOw many miles have you put on the coils?
Old Feb 1, 2013 | 05:05 AM
eossncsb's Avatar
just installed it now there is probably 50 miles on them
Old Feb 1, 2013 | 05:15 AM
Let's get a few more miles. Say 200 and see if it evens out if not we will tackle it then.
