3-4 inch long arm suggestions
Old Dec 8, 2011 | 04:16 PM
pbloom95's Avatar
Default 3-4 inch long arm suggestions
As christmas gets closer i was thinking about getting a long arm. Right now i have a budget boost and it is not the greatest. I am running 35'' Mtr/k's. I would like some long arm suggestions. Money is not a factor. I know a 4 inch would be a little too much. Thanks in advance.
Old Dec 8, 2011 | 05:03 PM
sa29560's Avatar
The most common long arm kits that have me scratching my head are the Rock Krawler, the full traction, Clayton, and teraflex.
All have their advantages, i personally am leaning towards the TF arms and brackets with a crc link in the rear. Or just Clayton short arms, and a crc link. That would be under 2k, versus about 4k with the TF long arms
Old Dec 8, 2011 | 05:09 PM
WhosUrBuddiee's Avatar
If money truely is not an issue, then the EVO Double Throw Down is probably the best.
Old Dec 8, 2011 | 05:40 PM
pbloom95's Avatar
but that would give me a little too much lift for 35's. dont you think?
Old Dec 8, 2011 | 05:47 PM
Robar's Avatar
You, could do the EVO long arm w/ 4" plush ride springs. My next choice would be a Full Traction long arm. You could run that with 3 or 4" springs.
Old Dec 8, 2011 | 05:52 PM
With the plush ride springs and heavy bumpers.... it would be perfect.
Old Dec 10, 2011 | 04:57 PM
SergeantChuck's Avatar
I went with the TF Elite LCG 3" Long Arm. It has a great ride and lots of travel. I'm running close to 35" tires and they almost look to small. Glad I did not do the 4". I still have plenty of room for 37s when I decide to upgrade.
Old Dec 12, 2011 | 05:57 AM
wayoflife's Avatar
JK-Forum Founder
the factory JK arms are A LOT longer than the old TJ's and you really don't need long arms for just 3" of lift and 35" tires. in fact, i wouldn't even bother going up to 4" as that's a lot of lift for such a small tire. if you're planning to go to 37's or bigger, more lift and a long arm kit would help your on pavement ride and handling but aside from that, you might want to save your money and maybe just get a good, complete short arm kit.
Old Dec 12, 2011 | 06:55 AM
tslewisz's Avatar
pbloom95 - I was in the same situation as you. I just put on a Rock Krawler 2.5" Max PRO system. I'm very impressed with it.
