3 or 4 link front suspension?
you will need a front drive shaft and if you are a two door a rear as well. as to what shocks to run you will want about a 11 in of travel shock and some bump stops to fit what tires your running.
This is true, but the 3 link does fine at speeds offroad. I've had mine up to sixty or so on the beach, and it handled great. Amazing articulation too. If you mainly to pre-running, get the four link, otherwise do the 3 link. 30000 miles over almost 2 years, including 50 miles/day on the highway @ 75 so far. Also check out bilstein 5100 shocks. A set is about 300, and best shock I've ever owned, bar none.
