3/4 spacer on OME ??
Old Apr 16, 2008 | 03:49 PM
RESCUEJPF's Avatar
Default 3/4 spacer on OME ??
Love my OME heavy kit but I still Have a little sag in the front due to LOD Tmax winch and 54" jack on the hood..... Can I add 3/4" spacer to the front or will it cause problems since OME doesnt have extended bump stops...... Shock problem, brake line issue or any other problems that may happen....... Thanks alot as usual........ I guess I could ad wieght to the Back!!!
Old Apr 16, 2008 | 04:23 PM
Northridge4x4's Avatar
Sponsoring Vendor
Did you put the OME spacers in?
Old Apr 16, 2008 | 04:29 PM
RESCUEJPF's Avatar
Yes.. Just no rear weight yet........ You will fix that when I order rear bumper
Old Apr 16, 2008 | 04:38 PM
Sponsoring Vendor
I personally would leave it then. Or take the OME spacer out and get a 1/2 spacer.
Rear bumper should not be to much longer
David
