3.6 owners only!!!!!!!!!!
#31
1- 4.10 (stock rubi gear)
2- 37x12.50x15 maxxis creepy crawlers
3- 2300ish
4- flashpaq
5-really impressed with this 3.6 not much change from factory 32s
6- awesome 4:1 transfer case doesn't know they are 37" stickies
7- 42s on tons with 5.13 gears and an Ls series v8
3- 2300ish
4- flashpaq
#32
This is yet another gearing thread. But I think I want something different. I want info on your rig. Even if you are still running stock gears and tires I want to hear from you. If you have upgraded I want to hear from you also. This is what I am looking for.......
1 - What gear ratio are you running? 5.38's
2 - What tire size & Brand are you running? BFG Krawler 37's
3 - At 70 mph what RPM is your engine turning?Right around 3000ISH
4 - Are you using the AEV PROCAL or Superchips Flashpaq? ProCal
5 - On the road what is your opinion of the performance? Amazing
6 - Off road what is your opinion of the performance? Excellent
7 - If your fairy god mother came to you and said you will get any tire/gear package you want would you change and to what? This set up is ideal for me.
#33
This is yet another gearing thread. But I think I want something different. I want info on your rig. Even if you are still running stock gears and tires I want to hear from you. If you have upgraded I want to hear from you also. This is what I am looking for....... 1 - What gear ratio are you running? 2 - What tire size & Brand are you running? 3 - At 70 mph what RPM is your engine turning? 4 - Are you using the AEV PROCAL or Superchips Flashpaq? 5 - On the road what is your opinion of the performance? 6 - Off road what is your opinion of the performance? 7 - If your fairy god mother came to you and said you will get any tire/gear package you want would you change and to what?
1- 3.73
2- 35x12.5x17 Toyo mt
3- 2500 roughly
4- bullydog gt
5- keeps up with a '12 golf tdi with a tune, so decent
6- more than enough to spin all 4 and break axles (ask me how I know)
7- yes, 40s on one tons with a 5.xx gear probably
#34
1. 3.21
2. stock 225/75R16
3.around 2100 RPMs in sixth gear
4. nope
5. not bad it will get up and go
6. nothing to complain about now because I am running the stock tires
7.35" tires with 4.88 gears would be my ideal set up
#35
#36
2013 JK 6 Speed, averaging 17.5 mpg with mixed driving.
3.21
255/75/17 Rubicon Take Offs
2000
FlashCal
Not too bad, sometimes I need to downshift.
Real happy off road. I've done 3,800 miles like this in two months with a lot of it being on county dirt roads.
4.88's and 35's are in the future, will probably go with Duratracks. I'd need to swindle Eaton E-Lockers out of the god mother though.
3.21
2000
FlashCal
#37
1 - What gear ratio are you running? 4.10 automatic
2 - What tire size & Brand are you running? Hancook MT (34")
3 - At 70 mph what RPM is your engine turning? Not sure about 70 but at 62 I'm at 2000rpm
4 - Are you using the AEV PROCAL or Superchips Flashpaq? AEV
5 - On the road what is your opinion of the performance? Sluggish up until 2000 rpm, then the motor wakes up and it really kicks.
6 - Off road what is your opinion of the performance? No complaints
#39
1. 2013 4dr Sport Auto 4.56
2. 35x12.50-17 ProComp Xtreme AT
3. At 70 mph I'm turning 2650RPM
4. AEV Pro Cal (this is not optional if going from 3.21 to 4.56 it will go to 3rd gear and stay)
5. Performance on the street is good does still shifts at too high an RPM
6. Good
7. I wouldn't change anything with the tires/gearing but wish I had gone with better springs.
6. Good
#40
2013 JKUR. Coming from a 2011 JKR
4.10'
Toyo MT 285/75/17
~2600-2800
Bully dog
Compared to the 3.8L its great and in the mtns compared to the 3.8. Doesn't down shift near as much , so much more power
Very happy. I like the 5 Spd auto manually swift in and out in the lower gears for off roading. As for it capability vs the 3.8 both are good at the low end going over obstacles not much differences there. I did find myself needing to go into 4Lo sooner with the 3.8L to percent tranny overheating issues that the 3.6L doesn't appear to have.
4.88's for 35's and maybe even 37's in the future
Overall very happy with the upgrade from the 3.8L
4.10'
Toyo MT 285/75/17
~2600-2800
Bully dog
