3.8 pinging
Old Mar 21, 2012 | 10:31 AM
  #271
itsajeepthing91's Avatar
Originally Posted by Ryan0260
Just curious as to how you drive it? Short frequent trips? What kind of rpm range do you drive in? I have changed my driving habits somewhat and it has helped some with the pinging.
In my situation I think those questions are irrelevant. New valves were put in 2 months ago and the problem is back already this motor has issues. The new valves solved the problem for about a month so I'm guessing she carboned up again which wouldn't be normal in that span of time even if it did nothing but idle. Perhaps bad rings causing excessive oil consumption and carbon build up.
Old Mar 21, 2012 | 10:35 AM
  #272
Originally Posted by JPop
Is there oil in the air inlet tube or varnishing in the throttle body? What do the plugs look like? Any fouling?
No oil in inlet tube or varnishing in throttle body. Haven't pulled a plug yet as I am hoping after consumption test warranty will go good for new short block but I will check.
Old Mar 21, 2012 | 10:36 AM
  #273
jkfanatic's Avatar
I ended up running some marvel mystery oil through a tank of gas and then running a tank of 93 octane gas and it cleared it up. I only make short trips and I idle often but I think its the gas for me. oh, I also changed my oil with 5/30 last time too but I'm not sure if that did anything. I will go to 10/30 next oil change though.
Old Mar 21, 2012 | 11:58 AM
  #274
Ryan0260's Avatar
I think there is a good chance of it being the rings. I have a feeling that my motor is doing the same
Old Mar 21, 2012 | 12:22 PM
  #275
Yeah from what I've read bad rings are relatively common in these motors. I hope your motors problems are not as severe as mine are you still under warranty?
Old Jan 27, 2013 | 05:50 PM
  #276
chevyboy67's Avatar
i have been dealing with this for weeks now. its driving me nuts and reading 27 posts here im about to shoot myself.. I HAVE AN 09 JK WITH A CAI 35'S MBRP EXHAUST, VIPER THROTTLE BODY AND FLASHED FOR 93 TUNE I ALWAYS RUN 93 SINCE I BOUGHT IT... I DONT KNOW WHEN I STARTED TO HEAR THIS PINGING SHIT BUT MINE DOES IT ONLY UNDER LOAD FOR ABOUT 8 MINUTES THEN ITS GONE... NO DEALER CAN HEAR IT OR MECH THEY ARE ALL DEF.. I HEAR IT ALL THE TIME.. SOME DAYS ITS WORSE THEN OTHERS... I HAVE NOT CHECKED FOR A CRACKED MANIFOLD YET THATS TOMORROWS JOB I HAVE ALSO RUN SEAFOAM IN IT STILL PINGS.... AT OF ALL THE JEEPS AND JEEP OWNERS AND MECH'S IN THE WORLD NO ONE KNOWS WHAT THIS PROBLEM IS??????? IF I DONT GET IT RESOLVED REAL SOON CUMMINS 4BT IS GOING IN! JUST FYI IT HAS 30K ON THE CLOCK.... IF ANYONE WANTS TO DISCUSS THEIR PROBLEMS CALL ME 917-902-5646
JOHN
Old Jan 27, 2013 | 06:06 PM
  #277
Mr.T's Avatar
Community Favorite
JOHN
Try going back to the stock tune and see what happens to the spark knock. What may be happening is that the 93 Tune has too much spark advance for the fuel you are using.
Old Jan 27, 2013 | 06:18 PM
  #278
Ryan0260's Avatar
They can give you a modified tune, but honestly, it takes away all the benefit and performance. Try doing a carbon flush to the motor. Chrysler combustion chamber cleaner, follow the directions. It may take more than one treatment. Also, change the pcv valve if you haven't done so
Old Apr 2, 2013 | 09:10 AM
  #279
Livenudes's Avatar
Found out the exhaust manifold had a crack on it and that might be the problem with my pinging
Its getting replaced Thursday morning
Ill keep u posted
Old Apr 7, 2013 | 05:45 PM
  #280
barnettd's Avatar
Default Pinging and gas
Mine seems to clear up depending on the octane of gas and which brand I use...
