3/8 vs. 1/2 torque wrench w/ same specs?
Old Jan 13, 2010 | 09:27 AM
Northern Wrangler's Avatar
Default 3/8 vs. 1/2 torque wrench w/ same specs?
Hey all, I've read the threads I found in the search function but this isn't covered. A local store has a 3/8 and 1/2 torque wrench on sale for $68 and $74. The 3/8 is shorter and looks easier to handle under the JK and the 1/2 is longer and thicker. Now I've read to go with the 1/2 as it handles more torque but... each package says that the wrenches are both good from 30-250 ftlb...
So my first inclination is to just go with the 1/2 but what do you think? I won't be using either for major jobs just checking torque after wheeling and changing/ rotating wheels.
Old Jan 13, 2010 | 09:30 AM
bly109's Avatar
Get the 1/2". The longer handle will give you a lot more leverage when torqueing suspension bolts.
Old Jan 13, 2010 | 09:35 AM
KenB1010's Avatar
Yup, get the 1/2" one.
I just gotta say that stuff about the middle school is just soooo wrong.
Old Jan 13, 2010 | 09:58 AM
geebee's Avatar
go 1/2. thats canadian tire sale prices this week
Old Jan 13, 2010 | 10:02 AM
mkjeep's Avatar
1/2in x 10!
ronjenx's Avatar
Never heard of a 3/8" drive torque wrench that would go to 250 ft/lbs.
Are you sure it wasn't in/lbs on the 3/8" torque wrench?
If it did really say ft/lbs, it had to be a misprint.
Old Jan 13, 2010 | 10:27 AM
No seriously I read both packages. They have the same specs printed. Thanks for the help guys. I'm headed down to crappy tore now to pick the 1/2 one up!
Old Jan 13, 2010 | 10:35 AM
ronjenx's Avatar
If both wrenches are there, read the actual scale on the 3/8" torque wrench. See what it is rated in.
Just curious because I've never seen a 3/8" drive that would go to 250 ft/lbs.
Old Jan 13, 2010 | 11:10 AM
Mark Doiron's Avatar
If you can get 250 foot-pounds out of a 3/8" drive torque wrench, please let me know which NFL team you play for. Either that of you shuck oysters for a living.
Old Jan 13, 2010 | 11:17 AM
codysanders's Avatar
Originally Posted by 2k2wranglerx
and before everyone FREAKS out, i know there's no guarantee that an impact will go to the 250 ft/lb or whatever.... but all i know is i couldn't BUDGE the control arm bolts tighter with the 1/2" drive tq wrench after cranking them down with one of these....
there is such a thing as to much torque. you can overtighten and do just as much damage as undertighting (mabye more). this is especially true with your lug nuts and the rotors warping. but hey it is your jeep so do what ever you want. thats just my view on the impact as your torque wrench.
