3" FT Premium Install
Old Jul 14, 2007 | 05:01 PM
StevieRay's Avatar
Default 3" FT Premium Install Problem
I have finished my install of the 3" Premium FT lift. Although I had to modify several parts, its on. Now though, I have a knocking sound in the front end when I turn the wheel back and forth while driving (not while still). I have retightened everything and cannot seem to locate the noise.
Anyone know of any "tricks" that I can use to locate the noise on something that only happens when its rolling? Or has anyone had a similar problem that may know what is causing the knocking noise?
Any help would be appreciated.
Last edited by StevieRay; Jul 14, 2007 at 05:22 PM. Reason: Title needs to indicate theres a problem
Old Jul 17, 2007 | 01:03 PM
easttnruby's Avatar
Default i alos have issues with lift
I too am runnung the FT premium lift and had a hell of a time getting the rear track bar bracket mounted. Prob going to just get the RE rear adjustable arm. Up front though I have a dead spot in my steering and I cant figure it out. At center steer I can move the steering wheel to the left and right about an inch or more and get no movement at the wheel. Could I have a bent tie rod or worse? Help!!:sad:
Old Jul 17, 2007 | 01:26 PM
jared1843's Avatar
I had a very similar sounding problem shortly after my install of the same kit. Turned out to be the track bar bolts. They were pretty tight, but when set to the appropriate torque spec the knocking went away....
Old Jul 17, 2007 | 01:28 PM
jared1843's Avatar
Have you tried re-torquing everything?
Old Jul 17, 2007 | 01:38 PM
easttnruby's Avatar
I ditched my install instructions .... I know dumb, but I didnt think I would have issues. Lesson learned, anyone have the torque specs on the lift kit
Old Jul 17, 2007 | 01:59 PM
BLKRuby's Avatar
It is most likely the trac bar. Did you grease it as you put the trac bar together? Do that and then tighen to a 125 ft/lbs. Same for the rear. Look at the write up for the economy kit, it has almost all torque specs on it.
Old Jul 17, 2007 | 02:07 PM
StevieRay's Avatar
Default Mine is good now
After the front end was aligned, the noise went away. I believe it was the two steering rods that are attached with knuckles to the steering. With un-aligned wheels these rods were rotating when I turned the wheel back and forth.
I am still having a problem with my strap bracket for the trackbar relocation bracket. It didn't fit right, so I will have to modify it to make it work.
Starting to get happy with the install now though (especially since it is almost complete!) I sure hope I saved a lot of money installing it myself since it was quite a big job. If not, at least I learned a lot!
Old Jul 17, 2007 | 03:22 PM
BLKRuby's Avatar
Just use a Dremmel and widen that hole for the braket out. I assume that is where you are having problems?
