3" Full-Traction SRS kit rear spring looks bent
Installed my lift a few months ago, was under the truck and noticed the rear springs look like they are bent almost like a mild S. The lower arms are stock length and i adjusted the uppers so the rear was pointed at the tcase (forgive my non-technical terms). Should I shorten the upper arms to get the springs straight? It seems like that would drop the front of the axel down which looks like it would straighten out the springs. Just not sure if that would put too much strain on the lower joint. In searches I found that 19.5" was a good starting place?
Stock Drive shafts, and I have a 4door with 33's.
Yup, like WOL said that looks normal if you adjusted your pinion angle. If it hits your track bar or if it bothers you the wedges should work great with your 3" lift. I used the wedges with my 3" lift. When I latter installed 4" springs and pushed the axle back I used the JKS perches to get the bow out.
