3" Lift with 35's
Old Apr 5, 2013 | 05:54 AM
MG2013's Avatar
I'm running a 2.5 TF lift and a one inch Performance Accessories Body lift. Can't complain.
Old Apr 5, 2013 | 06:01 AM
Ryan0260's Avatar
It is a good kit for the money, as long as you like the wheels and tires.
Old Apr 5, 2013 | 06:25 AM
Staytru06's Avatar
Looks like a good kit but seems to be missing a couple things which are no big deal to get like control arms and that 5th wheel and tire which is always a good thing to have..
Old Apr 5, 2013 | 06:31 AM
Congo's Avatar
Like adjustable control arms? What else? I want to do this right the first time if i can. Not find out about wear and tear on anything later.
Old Apr 5, 2013 | 07:38 AM
Jeepstin12's Avatar
At minimum, lower control arms, front and rear. Extended sway bar links, brake line extensions, shocks, springs...... Can't ink of anything else at the moment.
Old Apr 5, 2013 | 07:39 AM
Jeepstin12's Avatar
Adjustable track bars preferred, but if you must, at least a relocation bracket.
Old Apr 5, 2013 | 09:30 AM
Rob 12B1P's Avatar
You might need a rear driveline to since you have a 2 door. I doubt youll find a kit that will do it but front lower control arms and rear upper control arms would be the best combination (unless your going to do all 8 which would be even better) IMO. That way your pushing the axel out to correct the geometry.
My Kit (Full Traction) came with front upper control arms and Im almost out of adjustment.
Dont forget to gusset your C's man.
Rob
Old Apr 5, 2013 | 10:43 AM
Jeepstin12's Avatar
Rob
I agree. I have the ultra srs 3" full traction on my 4 dr. My rear lowers are maxed to the shortest and just fall not the desired geometry. First thing I thought when I installed them was I needed to have uppers instead. They will be added later.
