3 questions
Old Dec 29, 2011 | 07:42 PM
Deep Water Terp's Avatar
Default 3 questions
I have 3 questions. I have used the search, but have not been successful.
#1 Would an adjustable track bar make my Jeep ride differently or just move the driveshaft so it is in line?
#2 Would a steering stabilizer be a noticable upgrade if I don't intend to go to 35's?
#3 Would sway bars that are longer than stock sway bars make a difference to the ride?
Thanks in advance! Any advice would be appreciated.
Old Dec 29, 2011 | 07:51 PM
jeeeep's Avatar
#1 i noticed a difference with an adjustable track bar, especially when i would load the back and pull a trailer.
if the rear is not aligned with the front, i think u would notice a difference as well.
#2 i still have the stock steering stabilzer with my lift and 35" tires. no difference than when stock. not worth the upgrade unless yours is already shot or damaged. get stock or close to it and save your money. if you are having front end wandering, shimmy etc... check your front end. there are several death wobble check lists that will help isolate other issues besides wobble.
#3. i wouldn't get longer sway bars, beefier ones made a big difference for me, I noticed the handling improvement, much better than stock.
hope this helps
