3" suspension lift + 1" body lift = 37s??????
I'm still waiting on my 4dr JK Rubicon, but am planning my mods and gathering parts now.
I intend to run either 36" Irok or possibly 37" Krawlers. Will a 3" lift with a 1" body lift clear 37" tires?
I'm not afraid to trim some sheetmetal for clearence. What is the best 3" lift? I am considering the 3" Full Traction Premium kit.
Thoughts?
Thoughts?
You may have to play with the bump stops a little. I'm running 36" Iroks with a 4" lift (+ 3/4" spacer up front) and they rubbed pretty hard in the front fender flares when stuffed and turned to full lock. I added a 3/4" spacer under the lower bump stops which helped quite a bit.
Thanks Phil. I wanted to hear some feedback from somebody who runs these. Where exactly were they rubbing? Top or sides of the tire? Do you think the extra width (13.50) causes more rubbing? Do you think a 37x 12.50 would rub more?
Sorry for the hijack!!!
I might just run the 3" lift and 37's and trim whatever is in the way. I love the big tire low lift look. My daily driver F250 has 37's with no lift.
that pic shows a really good stuff, but it's mostly height rather than width. with really long bump stops you'll be okay. and just pull the front fenders entirely.
i'll second the 4" + 1"BL for 37's
Apparently your time is worth nothing to you. Must be nice, but I don't have that luxury. Any time I spend working on something is time I could have been doing something else and/or making more money. Therefore it is a very simple equation; my time spent working = $$$$$$$$$$$$. As for a body lift being just a couple of "drilled hockey pucks," I will go out on a limb and say you have never installed one before, or at least done a good job installing one. They are quite a bit more extensive than that i.e. gas filler neck extension, bumper gap fillers or relocation brackets, shift linkage, radiator, etc, etc, etc.
