30 min LED back up lights using the stock bumper
Old 04-15-2014, 01:10 PM
  #51
Junior30's Avatar
Originally Posted by kylelever
Junior, Are those Rigids? Or a knock off? Looking for a knock off pair for my bumper build.
Knock off pair, got them for 60$ from China
Old 04-16-2014, 04:52 AM
  #52
kylelever's Avatar
How is the quality and light output?
Old 04-16-2014, 08:30 PM
  #53
Junior30's Avatar
The quality is really good and they are really bright as well. Im really impressed. They worth the money for sure.
Old 05-24-2014, 07:16 PM
  #54
TacomanBJK12's Avatar
Default To OP
Did you use anything to lock the lights in place?
Old 05-24-2014, 11:38 PM
  #55
Junior30's Avatar
Mines are bolted in the bumper.
Old 06-02-2014, 03:33 PM
  #56
Default Wiring help
I just got the same lights OP has and was wondering what the white wire is for? I know Red is power Black is ground but the white im confused about? thanks!
Old 06-02-2014, 07:18 PM
  #57
countrydude1992's Avatar
Are your lights for sure all white? I've seen a lot that look exactly the same but actually have white and red LEDs in them. The red is the + for the red LEDs and same for the white. Then a common negative.
I've also seen some that have 2 brightness settings. One wire triggers half the LEDs and one triggers them all.
Old 06-03-2014, 04:32 AM
  #58
cormac827's Avatar
Originally Posted by countrydude1992
. Are your lights for sure all white? I've seen a lot that look exactly the same but actually have white and red LEDs in them. The red is the + for the red LEDs and same for the white. Then a common negative. I've also seen some that have 2 brightness settings. One wire triggers half the LEDs and one triggers them all.
Throw the white light on same circuit as incoming red, see if you can use common power for both.
Old 06-03-2014, 08:34 PM
  #59
The white was actually the ground the red was power always thought black was ground huh
Got mine all installed work really good ill post pics up tomorrow
Quick Reply: 30 min LED back up lights using the stock bumper
