305/65/18 on stock Sahara wheel
Many tire company websites have fitment specs... which define the diameter and width ranges allowed on any given tire. Tire stores can usually reference it as well. They must follow specs to avoid lawsuits.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
A lot of people are running taller/wider tires on stock rims. You won't have any issues, as long as your local shop will mount them. (some won't, since they are narrower than the mfg's recommended width). This is assuming you take care of backspacing/clearance/rubbing, of course...
Thanks all! I'm already running 1.5" spacers just because I like the stance and in anticipation of bigger tires eventually.
I suspect I'll have to find a smaller local shop with fewer guidelines/rules to get them mounted. I already know of at least one that I'm sure would do it, especially if I buy the tires through them.
I have a talk with the counter guy each time when I go in so I am not wasting anyone's time. My local Discount Tire knows me by now (not sure if that's good or bad, but it helps me out a lot), and will accommodate me in most instances.
