315/70/17 Duratrac Tread Width?
Old Aug 25, 2011 | 01:03 PM
Mallow's Avatar
Default 315/70/17 Duratrac Tread Width?
Can someone that has the 315/70/17 Duratrac go measure the actual tread width of what actually rides on the road and post it here? I have been searching but can't seem to find it anywhere on the net. I am trying to calculate the correct backspacing so that the tread is covered by fenders due to laws.
Thanks
-Mallow
Old Aug 25, 2011 | 01:31 PM
Wandell's Avatar
Loved
It should be listed on Goodyear's website.
Old Aug 25, 2011 | 01:32 PM
Mallow's Avatar
You would think but I have yet to find it. I see the section width as 12.7 but nothing about tread width listed on there.
Old Aug 25, 2011 | 01:35 PM
BleacherBum's Avatar
I googled tire width and tried the first hit (see web address below).
http://www.gtsparkplugs.com/TireCalculator.html
https://www.jk-forum.com/asset.php?f...0&d=1314307564
Here are the results of a 315/70/17 tire.
Name:	315:70:17 Tire size.jpg
I can not verify the results. I am sure someone else knows for sure.
crazyhorse02's Avatar
Some of it depends on your rim width as well. If you run a 9 in wide rim you will see a wider footprint but not as tall tire. My buddy has them in a 315/70/17 on MT Sidebiters and his are way wider than mine, which are on stock rims. But as stated earlier my tires are taller.
Old Aug 25, 2011 | 01:41 PM
Mallow's Avatar
Yeah the calculators give the section width but not the actual tread width. The tread width shouldn't change I wouldn't think with different rim widths but maybe it does. I know it affects height and how much it bulges out on the sidewalls but the tread lugs are molded into the tire.
Old Aug 25, 2011 | 01:45 PM
Mountain_Goat's Avatar
I'll measure mine when I get home. I mounted them on the stock Rubicon wheels.
Mallow's Avatar
Thanks I'd greatly appreciate it.
Old Aug 25, 2011 | 01:53 PM
John_Mora's Avatar
My Duratrac 315 70 17 on 28 PSI:
33.5'' x 12.7''
Old Aug 25, 2011 | 02:44 PM
Mallow's Avatar
I am looking for this measurement highlighted by red lines:
It appears to be smaller than the section width but maybe I am mistaken. I need to measure what actually rides on the pavement not the total width of the tire.
