315/70r 17's
Old Nov 10, 2012 | 07:43 AM
sdyeti's Avatar
For speedo re calibration though, they must be measured when mounted.
Old Nov 10, 2012 | 07:46 AM
Monte417's Avatar
yes they do
Old Nov 11, 2012 | 03:56 AM
kvhall's Avatar
Default Plus axel regearing
Also if your thinking about regearing you should use mounted diameter.
Old Nov 11, 2012 | 07:54 AM
Liquid741's Avatar
just do what most guys do...say it's bigger than it really is.
Old Nov 11, 2012 | 08:14 AM
suicideking's Avatar
The metric sizes tend to run small. The domestic sized tires 35 X 12.5 tend to be noticeably larger. Especially width wise.
A guy I wheel with bought some 315 / 70 / 17 thinking they were 35's. Once mounted, they did look closer to a 33 than a 35. He dumped them after a couple weeks and ordered 35 X 12.5.
It also depends on tire manufacturer -- BFG tends to run the smallest. GY tends to run closer to stated size.
Old Nov 11, 2012 | 10:35 AM
dave7200's Avatar
I have good year Kevlar's and they are 315/70-17 and they measure very close to 35 mounted but I do keep them aired rather high at 35 psi. Most people on here I notice run around 28 psi.
Old Nov 11, 2012 | 02:48 PM
Mschneid's Avatar
Originally Posted by Monte417
For everyones information I have seen almost every 35" tire available on the market mounted on jeeps courtesy of my buddys garage and not a single one has measured 35" while mounted. Tires measurements should be measured unmounted for true diameter
X2!! here here,
