315/75r16 with 2" OME heavy lift
Old 01-13-2017, 08:46 PM
2010jksaha's Avatar
I made no changes to driveshaft no issues there. I ordered the full kit from quadratec a while back
AVY(07KIT) 16090.0214
Old 01-13-2017, 08:49 PM
2010jksaha's Avatar
Originally Posted by 2010jksaha
I made no changes to driveshaft no issues there. I ordered the full kit from quadratec a while back AVY(07KIT) 16090.0214
I installed the lift myself at home simple tools and took it to get aligned no issues either. You get the panhard Rod extension but I did not install it did not need it. There is a write up on here about this lift good instruction that is what I used as a guide to install.
Old 01-13-2017, 08:55 PM
2010jksaha's Avatar
Link to write up by wayolife:
http://project-jk.com/jeep-jk-write-...ation-write-up
Old 01-14-2017, 04:58 AM
Chewmeista's Avatar
I cant thank you all enough for the posts. My nerves are definitely better now. I just need to keep an eye on the driveshaft and go from there.
Old 01-14-2017, 11:10 AM
rsmwrangler's Avatar
I run the OME HD coils front with the light duty coils in the back with RK correction wedges, the light duty coils were too light for the weight i have in the front and the springs were sagging a bit, aprox 150lbs, so i decided to change the LD for HD in the front only, the backs are fine with what i have, aprox 160lbs between spare and rear bumper.
Running 2" bumpstops front and rear with flat fenders and 315/70/17 KO2 tires that measure about 33.5" mounted in 17x9 wheels with -12 offset (4.5"BS)
I run 34 psi in my tires, so the coils are not harsh at all, though i can feel the difference between the HD and LD pressure rate in the front, if i didn't have the weight, i know those front HD springs will make the ride very stiff.
Front clearance at full stuff front
20170107_112537 by Wrangler RSM, on Flickr
Rear clearance at full stuff
20161124_081700 by Wrangler RSM, on Flickr
20161203_100647 by Wrangler RSM, on Flickr
Old 01-14-2017, 02:18 PM
EHarris's Avatar
Here is mine same set up. Might replace the coils in the rear. New rear bumper and tire carrier causing some sag.
Old 01-15-2017, 06:44 AM
Chewmeista's Avatar
Nice looking jeeps, thanks for the posts
Old 01-15-2017, 09:28 AM
I don't think anybody have asked, but to ease up the concern you had regardless your front driveshaft, did you go with the standard ome shocks ? If so, you won't have any issues with your front DS. Your front shocks would have to be longer than 25" for the DS to contact the exhaust and damage the rubber boot (this applies to JKU's, I don't know if it works the same if you had a JK).
Old 01-15-2017, 10:27 AM
nthinuf's Avatar
You are talking about the boot in the middle where the two sections of the shaft slide in/out. No problem pulling that one off and driving without, I don't think any of the aftermarket shafts even include those. I was referring to the boot on the joint at the tcase. With the short shocks included in the kit, mine started spitting grease within a few thousand miles - just due to the increased angle from the lift height. Not saying his will wear through and spit grease, just a recommendation to check for it.
Old 01-15-2017, 02:27 PM
Chewmeista's Avatar
Im going with the hd springs and shocks. Im hoping it wont screw anything up. I have a jku with hard top. Maybe that will weigh it down enough. Thanks for the replies.
Quick Reply: 315/75r16 with 2" OME heavy lift
