33" or 34"
Old Jan 26, 2009 | 10:51 AM
dcjackson3's Avatar
Default 33" or 34"
Please help! I am going to upgrade the tires on my stock 17" rims but cant make up my mind on which. I know the size is about the same but I keep going back and forth. I also don't want to re-gear right now. Please post picks if u have any.
Goodyear- 285/70R17 33x11.5 or 305/70R17 34.1x12.2
Old Jan 26, 2009 | 10:56 AM
REL1203's Avatar
if you dont want to worry that much about regearing, go 33"... I have an Auto Unlimited with 33" KM2's and i already want to regear as its annoying the way its drives now. So as soon as my 33"s wear down, going bigger and regear.....
Old Jan 26, 2009 | 08:28 PM
JKMoses's Avatar
Now it depends on what rig, gear, lift you have. I am running 34” (305/70/17) MTR Wrangler in my Rubicon (4.10) with 4” superlift without any problem
Old Jan 26, 2009 | 08:50 PM
zjnoob's Avatar
I got some 33's but the actual tire size was 32.4, so I would go by the actual tire size rather than the rated size. Had I know the actual size I would have went with the 34's (33.6).
Old Jan 26, 2009 | 09:01 PM
troyboy's Avatar
That 34.1x12.2 probably requires a minimum 8" wide rim although you can fit on to your stock rims. Lots of people do that. Also, you will need wheel spacers for that wide of a tire and and a lift.
