33 inch spare
Old Jun 6, 2011 | 08:13 AM
ChryslerChris's Avatar
Default 33 inch spare
Got me a new set of P285/75R16's but began to wonder - will the new larger spare cause any issues with the stock tailgate mount?
Old Jun 6, 2011 | 08:28 AM
Fire Wrangler's Avatar
No, this is not true...You should be good with a 33 on the back of the tailgate, most guys run a 35 on there with no problems. I would recommend getting the Daystar extended tire bumpstops though.
Old Jun 6, 2011 | 09:08 AM
Wandell's Avatar
Loved
Will the Daystar bumpstarts help with these issues?
Old Jun 6, 2011 | 09:10 AM
xerofall's Avatar
I haven't noticed any problems. I did replace the tire stops. Anything bigger and you will block your third brake light and overstress the stock carrier. 33 inch is just right to keep it stock.
Old Jun 6, 2011 | 09:14 AM
danmojo82's Avatar
I didnt even know those daystar stops existed. That might help with mine which when the tops off with no radio on i can hear it creaking. Probably wobbling too much on the back which is more than likely what causes some carriers to fail.
Old Jun 6, 2011 | 09:22 AM
Wandell's Avatar
Loved
The Daystar bumpstops are cheap also.
Old Jun 6, 2011 | 09:48 AM
Orangeav's Avatar
That's what I did when I swapped my wheels for ProComps with 4" BS. I'm running the same size tire and they work great!
Old Jun 6, 2011 | 09:56 AM
xerofall's Avatar
Just remember "measure twice, cut once"
I had to modify mine after cutting a bit too much off... had to screw back on a big chunk and slowly grind down the area behind it.
I did the Daystar bump stops also. They do help out alot....They dont let the tire bounce around which is what might cause the stress on the tire carrier and tailgate...
Old Jun 6, 2011 | 11:51 AM
Christine's Avatar
Oh oh, I guess I'd better order bump stops. I have a 33" spare. I did the tailgate reinforcement brackets.
