33 on stock rubi
I read the faq but it was a little fuzzy, can I run 33" on my stock rims on my auto stock rubi and wheel ok without any other mods, with only minor rubbing when at full flex? Thanks for clearing this up.
My own search on this subject says yes. However, if you research tire dimensions, most 285/70/17 tires are within a 1/2 inch of the stock 255 in height. I guess that is why everyone says to go straight to 35's and be done with it.
You will have minor rubbing of the front tires against the sway bar end links at full lock. This can be cured with a couple of washers and the steering stop fix.
http://project-jk.com/jeep-jk-write-...top-adjustment
Your speedo will be a little over +1mph off as well.
