33inch Tire Pressure
Hey guys I have a quick question. I'm running Falken Rocky Mountain ats 285/70/17s on stock rims and have the psi set around 33. I notice that the front tires on the outside shoulder where its squared off seems to be wearing and back tires are fine. Is that caused from the front tires obviously being the steering tires? Sorry if I worded that wrong. Any help would be greatly appreciated!
I run 33psi on my 285/70R17 Duratracs with 17x8 rims and have nice even wear on my tires.
If you are getting wear on the OUTER edges of the tires, then something is amiss. Might want to check on the camber of the suspension (if that is even possible on the JK). Also, rotate your tires - it will help tons!
My old WRX had some good camber on the rear tires and rotations were normal and no abnormal wear was detected.
When you say "outer edges" do you just mean both edges of each tire (underinflated) or just the outboard edges (camber).
He explained to me that 40-65lbs on our light Jeep would be like having rocks for tires, and that these tires are designed for 3/4 ton trucks. So, I keep mine at 35...no issues so far.
