33s or 35s
Old Apr 30, 2008 | 11:19 PM
mattp313's Avatar
Default 33s or 35s
I am either looking at a 2.5 BB with 33's or a 3 inch lift with 35's . I was wondering if I would need new gears and how the 35s would effect gas mileage. Would I need to get the tires collaborated so it would be on point with my speedometer?
Old May 1, 2008 | 04:01 AM
pkdailey4's Avatar
The answer is yes to all three questions.
Old May 1, 2008 | 06:28 AM
Mark Doiron's Avatar
I'm running 33s with an RC 2.5 BB. I have the 4.10 diff's. It works okay. Definitely some loss of "oomph", but still tolerable. Gas mileage: Best measurement was after using the Hypertech to recalibrate for the new tires, and I got 15 mpg on one recent highway trip. That compares to 20 on a 5K mile trip last summer. Sorry, but I don't have a better comparison number for the new tires since most of my driving is on city streets. You can recalibrate the tires yourself if you buy either the Accupro ($180) or the Hypertech ($380).
Old May 1, 2008 | 06:33 AM
benjamin24's Avatar
matt, what gear ratio do you have now? and do you have the unlimited or 2dr? Auto or manual? All these things will determine how your jeep runs with different tires.
Old May 1, 2008 | 06:52 AM
Ryno's Avatar
It all depends on what kind of off-roading you're into. If it were me, I would go with a 33" all-terrain tire. Good on the street, good enough on the trails, and more civil and economical than a mud-terrain because of their lighter weight and tread design.
I've done some pretty technical trails in Moab with nothing but a 2.5" budget boost and 32s. 35s are overkill for probably 90% of people. They take all the challenge out of off-roading! They sure look good though.
Old May 1, 2008 | 08:16 AM
mattp313's Avatar
its an auto, 2dr, I am thinking 2.5 BB with 33's would be more economical seeing that I am not going to do a whole lot of wheeling. Are the 35s overkill if you don't offroad very much?
Old May 1, 2008 | 11:14 AM
Ryno's Avatar
35s are definitely overkill if you don't offroad very much. Heck, 33s are probably overkill too. 33s on a 2.5" BB will look great though. Since you're in Maryland you probably want a good all-season tire. I've heard nothing but good about Bridgestone Dueler A/T Revos. They have sort of a lightning bolt tread that looks cool and is designed for better traction in wet weather. The 33" Revos only weigh 43 pounds each (as opposed to a 68-pound 35" mud tire) and will save you several miles per gallon.
Good luck with your decision and post some pics when you're done!
Old May 2, 2008 | 09:42 AM
undertow119's Avatar
I'm not sure how you'd go about calibrating the tires, but calibrating the speedometer isn't too hard.....
Old May 4, 2008 | 11:18 AM
LinkSync's Avatar
If you don;t need that extra 1" of clearance then go the 33s or even 32's
I think the factory flash will go to 33 or maybe its 32...
Either way the error would be so slight you would have no clue there was any error.
Except you will look and calculate and be all anal like the rest of us.
LOL
I am on 35s and think that my next set will be 33s.
I had 32s and the difference in milage and so on is huge for me.
After a couple years of crawl'n an trail'n I think the 32s on a 2dr would give me enough air.
It all depends on usage tho.
I expect my 35s to last a good long while more tho so wont be doing any swapping out untill they are either shredded or MayPops.
Old May 4, 2008 | 12:31 PM
ksk's Avatar
ksk
Personally, id recommend the 33's for a daily driver....answers are yes to sll 3 of your questions aswell.... with 35's you should be looking at re-gearing...
KSK
