33's actaully measure 31"? Procal question
Old Feb 1, 2012 | 04:19 AM
lakeguy's Avatar
Default 33's actaully measure 31"? Procal question
I ordered a procal to help with the shift points on my Jk 2dr and went I went to measure it seems like the 33x12.5/15 duratracs only measure out to about 31" I am running 31psi.
Does anyone know what the factory settings are for stock sahara duelers. I purchased the procal mostly for shift points but if it is set for 31 from the factory maybe I just wasted my money.
Old Feb 1, 2012 | 04:26 AM
JK-Ford's Avatar
I don't think that you wasted your money. I like the Duro's better. Not sure about OEM specs. But any tire "mounted" will be shorter than "dismounted". Just sell the tires you don't like.
Old Feb 1, 2012 | 04:30 AM
lakeguy's Avatar
I love the duratracs and the look of the vehicle. I was wondering if I wasted my money on the procal becuase the main reason I bought it was for the shift points. If the computer is already programmed for 31's there might not be anything to change.
Old Feb 1, 2012 | 04:32 AM
MrDillClinton's Avatar
He means wasting money on the Pro-Cal.
I'd suggest running by a dealership with a tape measure on your way home from work and checking it out.
My 255/75/17 SRA's measure 31.5 inches.
Old Feb 1, 2012 | 05:05 AM
JK-Ford's Avatar
Gotcha! The OEM tires are 32". OP says the Duro's are 33". So -
Old Feb 1, 2012 | 05:09 AM
lakeguy's Avatar
My Duratracs actually are measuring 31". Maybe because I am only running 31psi. If they are the same size or possibly smaller than stock, this may defeat the purpose.
Old Feb 1, 2012 | 05:56 AM
PG-JKU's Avatar
Just curious - how wide are your rims?
JK-Ford's Avatar
The OEM's are manufacturer speced at 32". The Duratracs manufacturer spec is 33". This small of a change is debateable on the recal. But for me, there wouldn't be a debate. Keep the new stuff.
Old Feb 1, 2012 | 05:58 AM
lakeguy's Avatar
I have 8" rims.
Old Feb 1, 2012 | 06:03 AM
What is your actual tire size? I didn't think Duratrac made a 33 in an 17 or 18" wheel...
