33's vs 35's
Old Oct 16, 2013 | 12:19 PM
Mtn1954's Avatar
Default 33's vs 35's
Just got my new Rugid Ridge 17" wheels painted Commando Green. What cha think?.... and can't wait to get them on my '13 JKU. I don't plan doing any serious rock crawling BUT I'll climb the nth GA mtns OHV trails fairly often...
Mostly I plan to drive it everyday in ATL traffic.
I got 3.73 gears with AT..
Is there THAT much difference in 33's and 35's. Can I run 35's without a lift?
Old Oct 16, 2013 | 12:35 PM
jeepney425's Avatar
Dude, that's awesome. I have the same color on mine, the jeep not the wheels. How much did it cost you?
Old Oct 16, 2013 | 12:36 PM
jeepney425's Avatar
Show us a picture, once it's mounted on. Can't wait!
Old Oct 16, 2013 | 12:42 PM
kh202's Avatar
General consensus has been 4.10/4.56 is ideal for the 3.6L and 35's depending on the ammount of highway time you see. However, 3.73 wouldn't be bad at all. I dd 35's and 3.21's 60+ miles a day.
Those wheels look sweet by the way!
You could run 35's with no lift if you cut your fenders. Would be fine on the street but a little less than ideal if you plan on doing any flexing offroad. Throwing a 1.5" Teraflex leveling kit on there could get you by ($150)
Old Oct 16, 2013 | 12:46 PM
Tooadvanced's Avatar
Can you run 35's without lift is a yes and no answer. Flat fender it and adjust bumpstops no problem. Dont do that and you'll prob tear fenders off
Old Oct 16, 2013 | 01:00 PM
Mtn1954's Avatar
Wheels were $981 on line from 4Wheelonline. Cost me $360 to get em painted...
Old Oct 16, 2013 | 01:06 PM
Yellowfin's Avatar
There's more of a difference between 33's & 35's than there is between 35's & 37's. And yes, as has been mentioned, you can run 35's w/o a lift, but you'll need flat flares, trimmed rear pinch seams (not on a 13+ because they did it for you at the factory), good backspacing (4.5 or spacers), and proper bump stop. Honestly, though, I'd plan on bumping up to a 2.5" coil lift in the future. Doesn't have to be expensive with long arms, etc. Rock Krawler's 2.5" Stock Mod would be a great addition and will definitely enhance the ability of your rig. Not a must, but something to think about.
Waiting for pics of the wheels on the rig!
Old Oct 16, 2013 | 01:44 PM
Bkeeper's Avatar
Old school rule of thumb, daily driver with 0 - 2.5" lift go with 33s. Daily driver with more than two off road trips a month, 2.5" lift and up, go with 35s.
2.5" is the gray area where 33s start to look small and 35s start to look about right. Street MPG favors the 33s and off road performance favors the 35s with your 3.73 gears. So what is important to you wins out.
IMOP it is the combination/balance between looks vs mpg vs off road performance that should matter most not the trend at the moment.
Old Oct 16, 2013 | 02:21 PM
etl330's Avatar
having this same dilemma. just bought my aev 2.5" and need to decide on 33s or 35s
Old Oct 16, 2013 | 02:52 PM
Ncb's Avatar
Ncb
I was in the same situation trying to decide. I went with 35X12.50X17 KM2s because mounted and weight on wheels they measure around 33.75" on my JKU.
