35 to 37's. Help me decide.
Old May 30, 2013 | 01:23 PM
BlueBeast's Avatar
Default 35 to 37's. Help me decide.
Im currently running Cepek 35 MT tires and drive 80 street but need the traction in the Florida mud. I have a chance to pick up 37 Pro Comp AT or 37 Super Swamper TSL Radials. I'm running 3.73 gears and dont plan to update for a while. Will I notice a bigger power loss from the Pro Comps or Swampers?
Sent from my NOTE II on Sprint using JK-Forum
Old May 30, 2013 | 01:55 PM
DesertRat_Rubi08's Avatar
Yes, especially with only 3.73s. Many threads on this - but, plan on many more upgrades than just the tires you think you need. Because unless you have it all planned out i.e. gears, axles, steering, it's only a want. 37s require much more thought, and if it's a DD, I wouldn't.
Old May 30, 2013 | 03:10 PM
BlueBeast's Avatar
I've been reading a lot of the posts and write ups on running 37's. I probably should have given more info. I do plan to truss and gusset the Dana 30. I also had been planning to run 4.88 gears to keep from trashing the RnP. Then have a TrailDash on the list.
It is a daily driver. I put about 100mi a day on her and am getting 15mpg on 35 MTs. I was thinking the ATs would offer less resistance and still be ok offroad since I do light wheeling.
Old May 30, 2013 | 03:14 PM
BlueBeast's Avatar
Also, ive already done the Drag Link flip kit, Tuff Stuff 1 Ton tie rod, Adjustable Track Bar and a Bilstein 5100 SS.
Old May 30, 2013 | 03:25 PM
GIJK's Avatar
Go for it. Don't discount the Toyos I saw 37s for $319! http://www.treaddepot.com/tire/360270.html
Old May 30, 2013 | 04:22 PM
BlueBeast's Avatar
I found a full set of 37" Pro Comp Extreme ATs for $400. Seems too good to pass up.
Old Jun 2, 2013 | 02:28 PM
hdvoodoo's Avatar
I am running 5.38s on My JK with 37s. I drive it daily to the tune of usually 75 miles a day. I am about to but my second set of 37s. Since I put the gears in I am getting around 14mpg +/-
Old Jun 2, 2013 | 03:16 PM
BlueBeast's Avatar
What MPG's were you getting before the gears?
Old Jun 2, 2013 | 06:05 PM
Ryan0260's Avatar
You will notice a huge power loss and big drop in fuel economy with that setup...
Old Jun 2, 2013 | 06:11 PM
catahoula's Avatar
Part of me says go for it, but the sensible side says think before you do. Alot more pricy mods you might have to do to run those.
