35 inch KM2's on Rubicon
I strongly doubt you would need anything on a rubicon, due to the factory reinforced dana 44 axles in the front and rear. You probably could run 37s with no issues.
On a Wrangler X's dana 30 front axle - 35s would be the biggest I would go.
As usual your mileage or longevity in this case will vary according to where and how you drive it offroad.
But if you run a SEARCH I think you will find few complaints or failures with the D44s and 35" tires particularly if you runt the stock gears. From what I have seen most failures come from JKs with 37+" tires.
