35's with 18x10 Wheels?
Old Jan 23, 2012 | 11:01 AM
evo8boy87's Avatar
Default 35's with 18x10 Wheels?
Hey All
I am in the process of ordering all the parts to help my jeep grow up Anyways I am really set on the moto metal 0961's as i really want to paint the inserts white to match my jk. So the dilema I am having is...
I was originally going with a 18x9 until I found these
4wheelparts.com/Wheels/MO961-Satin-Black-by-Moto-Metal.aspx?t_c=11&t_s=210&t_pt=100100&t_pl=103630& t_pn=W%2fPMO96181050724N
They only make this wheel in 18x10 with the back spacing i need (4.50 minimal) The 18x9 is only 5.71 BS with positive offset and i refuse to run wheel spacers so i dont believe they will work.
My question is will the wheels i posted the link to work? And how do you all feel about running an 18x10 with -24 offset 4.56 Bs with centerbore at 78.3? Should I have any concerns or reasons to not run this setup? I will be running Nitto Trail Grapplers 35x12.50x18 Sorry for the NEWB question but i wanna be 100% sure before i drop 2700 bucks on wheels and tires. Thanks all in advance
Last edited by wayoflife; Jan 23, 2012 at 12:48 PM. Reason: please do not post direct links to non sponsors
Old Jan 23, 2012 | 02:38 PM
Ryan0260's Avatar
Originally Posted by Audiodogg
That's a pretty wide rim for a JK, but you don't plan on 4x4ing much do you? 18s will get beat up real fast if you plan on using your Jeep for it's intended purpose lol There are a few guys here running 18-20" rims and take them off road, but depending on what type of offroading you do, you may want to consider a small wheel.
Do a search on here for those size rims and find the answers you need. Or take stock wheel off and do some measurements in your wheel well to see if that'll be enough BS to clear all the inner components at full turn.
Nate
Not sure your logic on wheel size. A smaller wheel can get beat up as much off road as a bigger one...
Old Jan 23, 2012 | 04:04 PM
Ryan0260's Avatar
Larger wheels when rock crawling have a higher % of getting beat up on rocks vs smaller rims due being larger and having less sidewall on the tire. Going down a dirt road with rocks flying everywhere the larger rim will get hit more often than a smaller rim. That's just common sense and logic. I've ran every size rim before throughout my low rider days to 4x4ing days. Some things just make sense
Obviously they can all get damaged equally but driving a larger rim you have to expect more damage naturally compared to smaller rims. I've always found larger rims to last half as long as smaller rims in daily driving conditions. My 24s lasted 2yrs and were trashed lol My 15-17" rims usually last a good 4 years with abuse.
Nate
The op never said he planned I'm rock crawling. Anyways...I agree that 20's and larger are definitely more prone to damage because of the surface area but honestly the different between 17" and 18" not enough to tell someone not to get them. Now if he plans doing serious off roading I personally would be throwing on some high dollar rims
Old Jan 23, 2012 | 06:52 PM
evo8boy87's Avatar
not going to be doing much offroading I mean ill be out on the trails and doing some fun stuff. If an $850 set of wheels last we two years .. yay if not oh well cause im sure ill have the bug to change them again at some point in time.
My reason for the post was to get feedback on the width and if it bad to run that wide of a rim with a 35 or if any other suspension parts ie (tie rods, ball joints etc) ? how much wider the wheel would stick out and how it would look? Help me out here guys lol Bump it up
