35's and Budget Boost on a 2011 JKU really bumpy
Old Sep 17, 2011 | 02:39 PM
eptx_jk's Avatar
Default 35's and Budget Boost on a 2011 JKU really bumpy
Hi great info on here, I just put a set of BFG AT KO 35's along with a rough country 2.5 budget boost and the ride is kind of bump. I can really feel the bumps in the road alot more. Is this normal cause I went cheap and did the budget boost? any recommendations? thanks as always
Old Sep 17, 2011 | 02:43 PM
Ryan0260's Avatar
How much air (psi) is in the tires. Sounds like they may be over inflated
Old Sep 17, 2011 | 02:45 PM
eptx_jk's Avatar
They have 45psi, what do you think will be better?
Old Sep 17, 2011 | 02:47 PM
mkjeep's Avatar
Uggh, put 26-28psi , let us know how it rides then.
Old Sep 17, 2011 | 02:48 PM
Biginboca's Avatar
45 is way, way too much. Try like 26 to 28 psi.
Old Sep 17, 2011 | 02:50 PM
mkjeep's Avatar
deja vu...............
Old Sep 17, 2011 | 02:51 PM
eptx_jk's Avatar
Thanks Ill change it up and update you, should have done my homework
Ryan0260's Avatar
I would drop to 30 lbs and do a chalk test. Then if necessary you can go lower from there
Old Sep 17, 2011 | 03:09 PM
jesse0376's Avatar
If its a spacer lift it will also make it alot stiffer
Old Sep 17, 2011 | 03:16 PM
mkjeep's Avatar
How so???
