35's but I have a question?
I join the 35 club last weekend. 315/75/16 Goodyear DuraTrac's on MB TKO's 16x8.5 but with 5.5 BS. I know that everybody on here say you should have at least 4.5 BS so you will not rub. I have been driving it around since then and the only rubbing I have had, has been on the front lower plastic air dam which I have removed.
My question is do you think I will have any other rubbing issues? I have the TF 2.5 coil lift with 5100 bilstein shocks. The tire specs are 34.6" Dia and Section with is 12.3".
Thanks for any help!
I have basically the same set up... and I had the problem with the air dam... no problems with my pinch seem and I am running the same lift.
I got the wheels and tires from Discount, but I got the wheels about a year ago. I don't think Discount would do anything about the wheels. I made full lock turns and the only rubbing was on the front lower airdam.
I don't know if this was a good test or not, but I put a floor jack under the rear tire and jacked it up until the I hit the bumpstop. The rear tire did not hit the pinch seam or anything else.
