35s in load range C?
Old May 15, 2013 | 08:34 PM
cfr's Avatar
cfr
Default 35s in load range C?
At 55k, my Duratracs will need to be replaced by winter. Great all-around tire, but load range D in 315/70/17 and a little bit of a rough ride. Any aggressive AT/MT 35s in load range C other than the MTR w/Kevlar?
-Charles
Old May 15, 2013 | 10:03 PM
Huggerls1's Avatar
Thought you can get the duratracs in load c range? Unless you are going for something different
Sent from my high tech pocket watch
Old May 15, 2013 | 10:12 PM
Brightwhite's Avatar
I know you said you weren't interested in the mtrk, but I too am in Colorado and love my c rated mtrk. I run them at 25psi and they are awesome on the road in all conditions. I'm on my 2nd set and have nothing but great things to say.
Old May 16, 2013 | 03:36 AM
kh202's Avatar
My 35x12.5x15 KM2's are C. Not sure about 17's
Old Aug 14, 2013 | 07:42 PM
cfr's Avatar
cfr
Found another option in load range C today: Kumho Road Venture AT KL78. 35X12.5R17LT. Mild AT through.
Old Aug 15, 2013 | 01:15 AM
JK Inspired's Avatar
LOAD RANGE (sidewall plys) is an over rated aspect of ride quality. There are great tires out there with 8 and 10 ply sidewalls.
Old Aug 15, 2013 | 07:41 AM
Ryan0260's Avatar
Agree! In my experience, the 8 and 10 ply tires run at the proper psi for the weight of the vehicle, don't ride significantly worse than the lighter duty tires. I would rather have the stronger sidewall myself.
Old Aug 15, 2013 | 04:24 PM
planman's Avatar
Forum Tech Advisor
What you really want to pay attention to is the service description load rating at max psi.
There are load range D tires that are stiffer than some E's.
In the end, I'd depends a lot on the weight of your rig.
I run load range E, 125Q, 3640 lbs max at 65 psi, Toyo 35x12.50R17s on my lifted, Ram 1 ton crew cab diesel and love them.
I ran the same model tires on my 2 dr JK for several months and absolutely hated them. To get a compliant ride, I'd have to run them under 24 psi. At 24 or less psi, the tires started every day with flat spots until they warmed up. It sucked for a Montana winter.
My truck weighs about 2k-2.5k lbs more than my 2 dr JK did at the time.
I would never run a 125 load rated tire on a 2 dr JK again.
Old Aug 15, 2013 | 05:35 PM
RND's Avatar
RND
A 285/75/17 KM2 has a 121/118Q load index rating. Why the two weight ratings?
Old Aug 15, 2013 | 08:32 PM
planman's Avatar
Forum Tech Advisor
One for when they are run on a single wheel axle and the other for the rear of a dually truck.
