35's Modifications
Old Feb 12, 2011 | 05:52 PM
msp1972's Avatar
Default 35's Modifications
What did everyone do with that pointy metal seam in the rear? The question is, cut or bend? Let me know please
Old Feb 12, 2011 | 05:57 PM
JK.nick's Avatar
I didn't even do anything with it. Let's just hope it doesn't cause problems when i flex out more!
Old Feb 12, 2011 | 06:00 PM
jeepmedic's Avatar
I gracefully removed it with a plasma cutter.
Others usually just pound it over with a big f!@#! hammer.
Old Feb 12, 2011 | 06:01 PM
msp1972's Avatar
It doesn't affect anything? I thought for sure it would touch
Paws's Avatar
trim them with a hack saw or smash them with a hammer.
Here is a good thread...
https://www.jk-forum.com/forums/show...ght=Pinch+Seam
I need to do this to mine before I get 35s.
speed2005's Avatar
won't cutting it or bending it hurt the re-sale value?
Old Feb 12, 2011 | 06:02 PM
azrwilkinson's Avatar
You can hammer it down, grind it down, cut it down, or file it. Depends on if it is a real problem. I used a 6 inch grinder with a sanding disc. It a lot easier for me too controll and doesnt just chew it up. Good luck on what you do.
Old Feb 12, 2011 | 06:03 PM
msp1972's Avatar
Once you cut it, did you seal it with anything
Old Feb 12, 2011 | 06:33 PM
Olean NY Jeeper's Avatar
May be but when I'm dead who cares.
Old Feb 12, 2011 | 06:50 PM
Paws's Avatar
Some seal it with primer then color match paint. Some have used bed liner.
If you have the Rubicon lots of people cut "trim" the rock rails as well as they will rub on the 35s.
