35's with no lift
Old Dec 20, 2006 | 07:58 AM
atvin411's Avatar
Default 35's
I was just asking thanks for the input I have 35's mt claws that are going on when i get new rims and I will get a 2" lift the green unlimited looks perfect.
Old Dec 20, 2006 | 11:25 AM
Cdash's Avatar
Originally Posted by gtndrty
I had installed a 2" spacer to level my Unlimited out, with 285's. I then ordered 2.5" coils for front and rear, as well as, 35x12.5x15 Mickey's on 15x10 Black Steely's. My wheels and tires came in before my lift, and of course I had to get them on, just to see. They fit, as long as you could put up with them rubbing on the front bumper while backing up. I should say that I got rid of that plastic "air dam", and all associated steel. The tires would have hit that for sure. I have since installed the springs and it is nice. I've got adjustable front upper control arms on the way, to adjust my caster. It shakes alot if i'm going under 15 mph and hit the right bump. So to make a long story short, not without at least a 2" lift up front, and zero interest in using your JK for what it was intended.
Are you running 2.5" (coils only) or 4.5" (coils and spacers) with the 35's?
What did it look like with the spacers and the 285's? Any pics of that?
ID:	285506   Click image for larger version
ID:	285507   Click image for larger version
ID:	285508   Click image for larger version
Old Dec 30, 2006 | 01:39 PM
TexasChopper's Avatar
I bought my 2dr Sahara today and I am ready to start ordering....So is safe to say I could run 35's with a 2inch econo lift, and wheel spacers? I am planning on removing the side steps, and I can see where the body is going to have to be trimmed a tad in the rear. I should add this vehicle is going to be a for crusing around town, and will not go offroad.
Old Dec 30, 2006 | 02:05 PM
Piginajeep's Avatar
it works, i installed 35's friday, and then promptly removed them.
You'll rub turning, not to mention bottom the tires out on the body in the back.
Old Dec 30, 2006 | 02:10 PM
Thanks for the input. I figured it would rub during extreme turning but that's fine. My TJ rubbed with 32's and no lift, and it didn't bother me. By chance did you get any pics before you removed them? Look good in your opinion?
ID:	383837   Click image for larger version
ID:	383838   Click image for larger version
ID:	383840   Click image for larger version
ID:	383841   Click image for larger version
ID:	383845   Click image for larger version
ID:	383846   Click image for larger version
Old Dec 30, 2006 | 02:18 PM
Piginajeep's Avatar
it looked like a hotwheels jeep.
The turning radious is about like a limo or a big semi, its just not pratical.
Any slight bump, and its going to rub just about anywhere around the tire.
I wouldnt want to drive anywhere with the jeep,
I did take some pictures, I dont have access to them right now.
Old Dec 30, 2006 | 02:22 PM
&^*&**$@^%#.... that's not what I wanted to hear. Sounds like you just cost me some more money I guess there is no point in having something that is ridiculous to drive though
if you could post those pics when you get a chance that would great.
thanks again for your input.
Old Dec 30, 2006 | 02:35 PM
BigO's Avatar
Piginajeep...I see you're in Columbiana. Were you at 4WD Hardware on Friday? I saw a non-lifted 2dr rescue green X with Pro-Comp wheels and 35's being photographed when I was leaving the place. I stopped to talk to a guy standing nearby to inquire on the tire size. It looked like it would rub bad going over a curb.
I was in my silver Rubicon Unlimited.
That wheel/tire combo would look sweet on a lifted Jeep.
Was that you? Just curious....
Old Dec 30, 2006 | 03:30 PM
Piginajeep's Avatar
yep,,, that was my wife and I.
what you didnt see was how long it took me to turn into that spot.
Originally Posted by BigO
That wheel/tire combo would look sweet on a lifted Jeep....
When the FT 3" comes in, they'll be on our jeep.
ID:	385416   Click image for larger version
ID:	385417   Click image for larger version
Old Dec 30, 2006 | 06:00 PM
Docwinkle's Avatar
Mine has 33's and no rub, but they r the max i would go w/o lift
ID:	386942   Click image for larger version
ID:	386943   Click image for larger version
ID:	386947   Click image for larger version
