35's on sahara = damage
Old 11-10-2007, 05:48 AM
  #31
Piginajeep's Avatar
i beat the hell out of mine with 35's. It does fine, Alot of guys run 35's on TJ's and have no issues, the JK's a HP axle, beefer ring and pinion. You'll be good.
Just dont hit the skinny pedal if your tires are jammed on rocks, and dont keep on the gas if the front ends bouncing, thats when you break axles
Old 11-10-2007, 10:27 AM
  #32
capt scotty's Avatar
Default Go For It...it's Only Money
Finesse , (or easy on the skinny pedal for you guys in the south )
can go along way to save breakage. Hard jarring or bouncing will break just about any parts. The 35"s give you an advantage of rolling up and over things rather than binding against the side of it. Go enjoy your 35's .
besides it is only $1500. to replace it with a 44 if you do break......
Quick Reply: 35's on sahara = damage
