35's and TeraFlex
I installed the teraflex leveling kit on my unlimited jk and now would really like a set of 35's. I only went with the leveling kit because my left leg is amputated above the knee and its already a chore trying to get into the jeep. I won't be doing a lot of rock crawling or anything just mostly trails and some mud, so is it possible to do this or am I stuck with my 18's? Thanks for the help.
You can run 35s, you'll need to cut the fenders or get new ones. Also add wheel spacers if you're keeping the stock 18" wheels. As long as you don't plan on any serious flexing you'll be good to go!
If I remember correctly, planman says you can run 35s on stock suspension with a 1" body lift, 2" extended rear bumpstops, and flat fenders. So I see no reason why that 1" body lift couldn't be replaced with the 1.5" leveling kit and still go with the 2" extended bumpstops.
I guess I should have added in more in my 1st post, sorry for the confusion and I am really new at this jeep stuff. I am currently running 18x9 (18mm) Moto Metal 959 wheels with 285/65/18 Nitto Trail Grapplers. Now I assume the 18mm is the back spacing because I am not running spacers now and would really like to stay away from them if at all possible. Sorry for the confusion and thanks for all the help. Here is a pic of the current set up.
https://www.jk-forum.com/forums/show...do-they-relate
As noted above, replacing the stock flares with flat flares will give enough wheel well room to run the 35's without more suspension lift. The aftermarket flat fenders can be pricey, or you can chop up those pretty painted sahara flares:
https://www.jk-forum.com/forums/show...ht=reds+fender
You could stick with the 18s without spacers if you go with a 285/75/18 which is a 35. Goodyear MTR and Toyo MTs are available. Also Nitto terra grapplers and trail grapplers in 295/70/18 would work on your 18s without spacers and they run 34.5ish.
