35's under Fenders Help
I want to upgrade to 35's and Due to State Law i need to make sure that the shoes fit under the fenders.
Can anyone tell me if i were to get 35x12.5x17 tires and pair them with the AEV Pintlers (17x8.5 Size & 4.7" Backspacing) Would this set up stay under the fenders?
thanks!
thanks!
You can get some bushwacker flares
1/2 in or not, if the popo want to pull you over, they will find a reason.
Almost every trooper I have spoken with, none were dicks, has said that they use these little thinks as cause to investigate for bigger things.
If you in a Wrangler, you have a little going for you in terms of the suspicion bar. Now, tint out those windows, lower it and put a set of them 22" dubs on there, now you’re worth pulling over.
