37" still rub after triming rear wheel well.
Old Jun 9, 2013 | 01:22 PM
storch's Avatar
Default 37" still rub after triming rear wheel well.
08 unlimeted with 3.5" lift and bushwacker flats.
37x1250x17 toyo mt, I love the ride on the road, I trimed both the fender and the front pinch seam about 3/4" and still rubs.
should I cut more or do I need longer or adjustable controll arms.
thanks
Old Jun 9, 2013 | 01:31 PM
familytime's Avatar
JK Forum Regional Rep
Where's it rubbing?As you lift a rig,the axle will the tires inward.Are rubbing on the frame when steering?
Old Jun 9, 2013 | 01:38 PM
jim hensley's Avatar
Do you have upper and lower rear control arms. If not that worked for me. The upper arms push the axle back about an inch and solved my rubbing issues. I have 37's.
Old Jun 9, 2013 | 03:16 PM
storch's Avatar
what rear control arms did you use? are they all longer or only if adjustable.
uppers only?
Old Jun 9, 2013 | 04:48 PM
T&ERun's Avatar
Adj arms upper and lowers will be your friends. I run 4.5" with both uppers and lowers. I have yet to cut my front pinch seams and have not rubbed them. The rear pinch seams, however, I had to beat them with a large hammer to fold them over. I rubbed bad and actually ruined a tire. Even at 3.5" I think you'll be ok on the front seam as long as you set it up correctly. Fold the rear seams over though.
Old Jun 9, 2013 | 06:32 PM
jtphoto JK's Avatar
Did your lift kit come with extended bumpstops?
What is the backspace on your wheels?
Old Jun 9, 2013 | 07:57 PM
Maertz's Avatar
cut more off? im about to finish off my rear stretch and will have to cut a ton off.
