37" tires
Old Feb 9, 2008 | 11:48 AM
TxCop07's Avatar
Vet Army
Default 37" tires
ok here is the deal i bought a set of 37 x 12.50 17LT goodyear mtr's for $600 bucks. I am wondering what type of size wheels I should go with, i found some on quadratec there is a 17x9 with 5 in of backspacing and a 17x8 with 4.5 in backspacing. I am looking for the one that will make the jeep look wider and not rub.
also what else will i need to do to my 07 JK X to fit these tire. I have a 2" BB and a 2" BL for 4" total. Do you have to cut fendersor anything else?
thanks for the help
Old Feb 9, 2008 | 11:50 AM
Smoke6's Avatar
thanks for the help
Either would do. I'm running 35x12.50R17 on 17x9's w. 5"bs.
UCLA JK Rida''s Avatar
T:
Some minor fender trimming may be required with 37s. Some lifts clear them just fine...some lifts don't. In any case, that was a heck of a deal you got on the tires. Congratulations and post some pictures once you get those bad daddies installed!
Russ D.
Old Feb 9, 2008 | 12:10 PM
bOLsAK=3's Avatar
I have 5" back spacing on my wheels and only a slight flick on the plastic air damn. 4.5" will get rid of an issue like that (if you call it an issue at all) but you have a better chance of rubbing the rear fenders at full flex. If they are painted like the Sahara's are that could be an issue.
