37's rubbing on front lower control arm
Old Nov 8, 2008 | 10:01 AM
TexsDream77's Avatar
Default 37's rubbing on front lower control arm
The tires are rubbing slightly on the front lower control arms at full steering wheel lock after I start to move. Does anyone else have this problem. I'm running the stock control arms still. That is next on my list of things to upgrade. I'm not sure if the aftermarket control arms are shaped differently so they don't rub or not.
The tires are Pro-comp X-terrains 325/80 R 16 (37x13.50 R 16)
I'm running them on Craggar soft 8's 16x8 with 4.5" backspacing. They were great wheels with the 33's and no lift because the tires would tuck in the fenders without rubbing on the outer flare.
Old Nov 8, 2008 | 10:48 AM
jeffmarion's Avatar
After market control arms will pose more of a rubbing problem due to the fact that they are larger. What you can do is get some washers to adjust the steering stops on the knuckles.
Old Nov 8, 2008 | 11:00 AM
northsidejeepin's Avatar
I have the same issue with my 37's by 12.5 on 17X8'' wheels. Not much you can do except for what was mentioned above.
Old Nov 8, 2008 | 11:07 AM
What backspacing are on your wheels?
Old Nov 11, 2008 | 04:39 AM
WOL . if would be nice if you could chime in about yours. Anyone else for that matter. I know there are a lot of you running 37's. I would like to hear what you all did to clear the tires. And how many have a problem with the lower control arms.
Old Nov 11, 2008 | 06:23 AM
wayoflife's Avatar
JK-Forum Founder
the problem is the 13.50 width and yes, i had this problem as well. as mentioned, your best bet for now is to add a few washers to your steer stops and that will take care of the rubbing.
http://project-jk.com/jeep-jk-write-...top-adjustment
i now run wheel spacers and no longer have any rubbing at a turn. i do however now have rubbing of the fenders at a full stuff but i plan on trimming them soon
Old Nov 11, 2008 | 06:30 AM
jkkat's Avatar
I have this problem with my 35x12.50x17 ProComp X-terrains when at off-road pressures. 12-15
Old Nov 11, 2008 | 04:55 PM
So, what is your total backspacing now with the wheel spacer? And what is the width of your rim.
Old Nov 12, 2008 | 03:43 AM
I'm wondering if I should be looking at a set of 10" wide wheels. I like the 8's because of the bead holding ability.
Old Nov 12, 2008 | 05:44 AM
wayoflife's Avatar
JK-Forum Founder
total now is 3.25" of bs on a 8.5" wide walker evans beadlock.
for 13.50's a 10" wheel will work pretty good but like you, i would try to find a 8"-9" wheel.
