4.10 Gear & 32" Tires with Automatic Trans
Old Oct 28, 2008 | 12:44 PM
ncgrl1's Avatar
Default 4.10 Gear & 32" Tires with Automatic Trans
I am thinking about regearing to 4.10 from 3.73. Just wondering what RPM ypu are turning at 60MPH with 4.10 gear, 32"tires, and automatic transmission. Checking to see if I need to go further if I do it. Thanks, Randy
Old Oct 28, 2008 | 12:45 PM
RedneckJeep's Avatar
That would be just like a stock Rubicon.
Old Oct 28, 2008 | 12:46 PM
racer83l's Avatar
I'd go to 4.88 if I were you.
Old Oct 28, 2008 | 12:51 PM
MMO blk JK's Avatar
I'm yet to re-gear because it's so $$$$.... with that said I would at least re-gear to 4.56 or 4.88 to make it worth it. Also it leaves more options in the future for 35s. Although if you never plan to go bigger then 32 the 4.10s should be a perfect match. Then again... the 4.56 would be a perfect match, I just don't think going from 3.72 to 4.10 is worth it for the price, and you'll probably like the extra power with 4.56s.
Good Luck either way
Old Oct 28, 2008 | 01:30 PM
motorhead0320's Avatar
like they said, it not worth the money to regear unless you go at least 4.56. the 4.10 wont make that much of a difference. i would probably go with 4.88's even if you plan to stay with 32's for a while.
Old Oct 28, 2008 | 02:48 PM
PoorDad's Avatar
To answer your question, just under 2000rpm.
Old Oct 28, 2008 | 03:18 PM
schnee's Avatar
ditto on the just under 2k comment with stock rubi setup
Old Oct 28, 2008 | 03:33 PM
ncgrl1's Avatar
Thanks guys. Mine is turning around 1600-1650 so it looks like about 300-350 difference. That would seem to help some in power without taking a hit in gas mileage...
Old Oct 28, 2008 | 05:16 PM
joejeeper's Avatar
Default Axle assembly
Re- gearing is costly- I had 3.73 and went with mopar performance axle assembly 4.10 w/ lockers- of course I'll probably want 4.88 later. If you just want 4.10- I think the axle assembly swap is cheaper. My speedo is off, but w/ the 32" tires (The 33"s are about the same) at 55mph on dash turning 1750rpm- speed by GPS 55= 59ish
Old Oct 29, 2008 | 04:49 AM
Altitude Adjustment's Avatar
I'm experiencing the same, around 1900 RPM.
