4.10 gears
Old Dec 5, 2011 | 06:40 AM
zwvirtual's Avatar
Default 4.10 gears
Any issue with putting 4.10 gears in a 2009 Sport differential? Would I need new differential covers?
Old Dec 5, 2011 | 07:24 AM
NH-JK's Avatar
No issues... Unless you got them second hand. 4:10 typically comes in rubicons. If you got them from a rubi owner it will not fit. Your sport has a Dana 30 front, rubi has a 44 front.
If you bought them new, you should be good if your previous ratio is 3:73. If it was higher you'll prob have carrier issues.
Old Dec 5, 2011 | 07:26 AM
zwvirtual's Avatar
well I was looking at a used set of 4.10's from a Rubi, so I guess these won't work.
Old Dec 5, 2011 | 10:21 AM
nthinuf's Avatar
Nope, can't stuff d44 gears in that front d30. Also, if you have 3.21's currently, you will want a new carrier for the d30 also. (3.73 and higher, numerically, uses a different carrier than 3.21)
With an auto, you may as well go on up to 5.13's anyway.
Old Dec 5, 2011 | 11:47 AM
MTH's Avatar
MTH
^That.
It also wouldn't be worth the install costs to add 4.10s to a pre-2012 Sport auto trans. You could run 5.13s with stock tires if you wanted, and you'd like your Jeep a lot more.
