4.5'' shocks on 2.5'' of lift?
Old Jan 12, 2012 | 12:19 PM
DeJK21's Avatar
Default 4.5'' shocks on 2.5'' of lift?
Is it possible to use shocks meant for a 4.5'' lift on my jeep that has a 2.5'' lift or not? May be a bonehead question to some of you but figured i'd ask haha
Old Jan 12, 2012 | 12:23 PM
Joe Boxer's Avatar
Before saying "Nope," what kind of shocks? Most aftermarket shocks fit a specific lift height range. For example, a particular shock may fit a lift between 2.5" and 4".
Old Jan 12, 2012 | 12:35 PM
D_engel's Avatar
well..maybe with bigger bumpstops to prevent bottoming out the shocks and coil retainers on the frame side and axle side, you may be able to pull it off. You would be able to get some massive droop. Why do you want to run this setup anyway?
Old Jan 12, 2012 | 02:24 PM
cis911's Avatar
look at my set up (my signature) and i am running skyjaker softride hydro shocks that are ment to be for a 6in lift the shock lengths are Collapsed length (in.): 15.56 Extended length (in.): 26.750
Old Jan 12, 2012 | 03:14 PM
DeJK21's Avatar
the shocks are RE monotube shocks (part no. RXJ711 and RXJ712), it's not that i want to run this setup per se but my sisters fiancé just purchased the fox piggyback shocks so he was going to give me his old shocks (they're only 6 months old) so that i could save some money.
Old Jan 12, 2012 | 03:21 PM
DeJK21's Avatar
Originally Posted by chip80
You may need limiting straps to prevent the springs from coming off their perches at full extension.
so would you suggest purchasing the limiting straps and putting them on, or should i just stop being so cheap and save up for shocks that are meant for a 2.5'' lift haha
Old Jan 12, 2012 | 03:28 PM
cis911's Avatar
The question is "what is the extended length of those shocks?"
Old Jan 12, 2012 | 03:29 PM
cis911's Avatar
Oh wait didnt you say you have them on hand? Measure them.
Old Jan 12, 2012 | 03:34 PM
cis911's Avatar
I see people running an front extended shock lenght of 26.89in without limiting straps.
If i were you i would keep those shocks
buy crown extended breaklines if the lenght of the shock is too long (look up extended length)
buy the spring retainer
Old Jan 12, 2012 | 05:34 PM
Delux2769's Avatar
Buy the limiting straps for front and RC rear spring retainers. Use them "new" shocks and get some great looking axle pics.
