4.5" tips and tricks
Me and my buddies are going to start the install on my 4.5" rubicon Express Long arm kit on monday night and I am looking for a write up, or any tips and tricks from anyone that has done this lift.
I looked everywhere for a write up or step by step but can't find one.... If you know a link please post one. I remember reading once about a time about trying to get the bolt from the passenger upper control arm out, but can't find that either. any help would be greatly appreciated........ thanx in advance guys. Kevin |
cut that bolt off, and go buy a new one from Jeep, if they cant get one in time, just put a grade 8 in it until you can swap it out..
I've seen people take a pry bar to move the exhaust enough to get room, but I wouldnt suggest it. |
Originally Posted by Piginajeep
(Post 419011)
I've seen people take a pry bar to move the exhaust enough to get room, but I wouldnt suggest it. Also......... the suggested measurements for the control arms from Rubicon.......... is that measured bolt to bolt or entire length of arm? |
you have to replace the bolt if you decide to cut it off, with the exhaust in the way you can get the bolt out all the way.
When the new bolt gets reinstalled, just put it back on from the other side. I would think the instructions should have lengths for control arms look at steps 18 and 19 http://project-jk.com/gallery2/main....serialNumber=2 |
Just slide that bolt out far enough to cut it with a sawzall. With your RE long arm kit you will not be using that mounting point so you don't need a new bolt.
Originally Posted by Ctimrun
(Post 419033)
does the RE kit get new hardware? |
http://www.quadratec.com/Assets/Installation/77692.pdf
check this link out, the instructions from rubicon for that lift. if the link doesnt work, go to quadratec.com and look up that lift and u can download the instructions. i am getting the same lift but i am going to go ahead and replace the driveshafts. it is recomended. good luck on it, hopefully i will have mine next month |
