From 4" to 6"...Components?
Old Aug 11, 2010 | 02:14 PM
Question From 4" to 6"...Components?
All in all I would like to move upto 6" springs instead of my superlift 4" springs. I would like some sort of confirmation of the things I'd need to replace with this.
This is what I'm thinking will need replaced:
Teraflex 6" springs
Longer Quick Disconnects
Adjustable rear trackbar
Front & rear driveshafts
Things I think will work fine:
3/4" spring spacers
adjustable front trackbar
Adjustable control arms
What else am I missing??? Any info would be greatly appreciated.
Old Aug 11, 2010 | 02:20 PM
Brashanic's Avatar
Teraflex 6" springs
3/4" spring spacers
break lines, bumstops, extend abs line, shocks ? just thinkin' out loud not sure of any of it
Old Aug 11, 2010 | 02:25 PM
Not sure if I'd have to get longer bumpstops...I think mine are quite long enough..but I'd test it after installing longer springs
I think I could fab up something for the brake lines and abs line
As for the shocks...I have 5" rubicon express shocks...I could test the travel, but if all else fails, I could install the shock extensions that came with my original 2.5" BB (front and rear)
Old Aug 11, 2010 | 02:26 PM
Originally Posted by Freak
42" tires, hydro steer, long arms...you're talking some serious $$$
Do you have to go to Long Arms at 6" of lift? I thought some people were running short arm 6" lifts on here
Old Aug 11, 2010 | 03:00 PM
mmcan's Avatar
I would definitely go LA
Old Aug 11, 2010 | 03:02 PM
Brashanic's Avatar
this is exactly my dilemma. i can't wait to here the opinions
Old Aug 11, 2010 | 03:09 PM
TeraFlex's Avatar
Sponsoring Manufacturer
You could do a 6" and short arms, just don't expect a great ride or handling.
Teraflex 6" springs
3/4" spring spacers
Draglink Flip kit #1600440
Rear FORGED Trackbar #1754418
Longer brake lines, swaybar links, correct bumpstops.
Take a look at this pic and use it to compare with what you have already. What size of tires do you want run?
Old Aug 11, 2010 | 03:10 PM
Brashanic's Avatar
my bump stops are getting worn. my axle droops enough now that, my abs line is tight as can be. so i am thinking even if your bump stops are OK now you might need to space them if you lift.
bump stops new:
bump stops hammered: (you can't see it but my abs line is tight):
no other changes
Old Aug 11, 2010 | 03:11 PM
Brashanic's Avatar
i like your 6" long arm lift. i wish i would of done it first!
Old Aug 11, 2010 | 06:25 PM
everyone keeps asking what tires, but that's not really decided yet
I will probably move upto 40's at some point, but I want to move up first. I have 'good' adjustable short arms but I'm surprized that people are saying the ride would suffer so badly. I mean, I'm sitting at 4 3/4 lift right now, I know most 6" lifts run a little higher than advertised, but we're talking 1 1/4 inches above what I'm currently running.
I can flex without an incling of rubbing right now, and I'm running a 'skinny' 38. But I know that just like every other guy on here that I'm eventually going to go bigger if I keep this JK around for a while. I've considered mounting 40's just to flex it out and see what type of clearance issues I'd have, but I honestly thought moving up-to 6" springs wouldn't be a huge hassle or $$$ pit
maybe I was wrong
BTW my JK is a daily driver...at my current lift/tires I have no issues with driveability at all....been getting 16.5 mpg solid for over a year....highway & city...and it is still outstanding off-road as well. I've been wheeling with a fortified D-30 and I plan to until it breaks...I've got about $1K invested in the gears/axles/ and reinforcements, so I hope it holds up....but I plan on testing...and testing....and testing it until it doesn't
You'll need LA's for sure. I would at a absolute bear minimum so good adjustable short ones, I wouldnt even consider going that route. I'd address the steering as well. What tires are going to run?
