4.7 to our 6 speed
Old Mar 7, 2009 | 12:44 PM
rancid's Avatar
Default 4.7 to our 6 speed
will a 4.7 bolt to our 6 speed tranny or is there a adapter. i dont want a hemi.
Old Mar 8, 2009 | 07:11 AM
rancid's Avatar
i would think it will work with stock chrysler parts, the same 6 speed was used in the 05-08 1500 trucks with the v-6 and 4.7. so im thinking if you had the bellhousing from a 4.7 it should bolt up to our trans. making the swap very cheap, i checked on the 4.7 in junk yards and with low miles there around 700.00 to 1000.00 with harness. and i bet the motor mounts for the hemi jk swap would work for this.
Old Mar 10, 2009 | 11:08 AM
HULKGREEN's Avatar
The truck V-6 and the Jk V-6 are totally diffrent !!!! The chances that Chrysler used the EXACT same 6-speed in both are not very good .....
But , If you did your homework and the transmission is EXACTLY the same ....
HELL.......... GO FOR IT !!!!!
Old Mar 10, 2009 | 11:13 AM
Okie4WD's Avatar
This would certainly be worth a look. While a 4.7 is no Hemi, it certainly is a better choice that the weak ass engine we have now.
Also MUCH cheaper.
